June 5, 2026 - June 12, 2026
Vercel Weekly - June 15, 2026
Top Highlights
- AI SDK 7 now supports HarnessAgent, a unified API for programming established agent frameworks like Claude Code, Codex, and Pi, allowing developers to switch between different agent harnesses as easily as switching models.
- Vercel Drop launched so you can deploy a file or folder without Git, the CLI, or any local setup. Just drag it into your browser and it's live.
- Vercel AI Gateway now let's you set a spend cap on any key. When the limit is exceeded, it rejects further requests on that key until the budget resets or you raise the limit.
- Noticed App — browser based capture and reflection app
- built SwiPR — swipe-to-review GitHub PRs with AI context
- ogimagecn — Beautiful OG images, made simple
- HTML Deployer — browser workflow for turning AI-generated HTML into a live Vercel page
- Border Code — free open-source on-device coding agent that runs entirely in your terminal
Don't forget to visit the #showcase to see what else everyone is building
Resources
- DeepSeek enters the fight for token volume, Anthropic continues to dominate spend
- How Okara runs CMO agents for 120,000 companies on Vercel
Events
- This Week
- Next Week
You can always find the latest Vercel events on the community calendar
More Updates
- Domain Search is now available through the Vercel CLI
- Budgets for API keys on AI Gateway
- Claude Fable 5 now available on AI Gateway
- Threshold billing is now enabled for Pro teams
- DeepSeek models now available via Azure on AI Gateway
- Vercel plugin is now available in Grok Build
- Introducing Vercel Drop
- Program Claude Code, Codex, Pi and other agent harnesses with AI SDK
