I have the same problem… I could not use my gifted credits after I used up my monthly credits…
Hi , welcome to the Vercel Community!
I'm sorry you're facing this issue. Could you share a screenshot of the error? Also, from the billing page showing the left over credits?
Problem solved! Thank you, Anshuman!
I encountered the same problem as well. May I ask how you solved it?
After I linked a credit card to the AI gateway, it worked magically…. I don’t know if that is the reason…..
Hey are you still facing this issue?
I'm glad it worked. But, they are unrelated. Highly likely the issue got resolved sometime around that.
Hi, my friend tells me that he still has this issue
Facing the same issue, though i have plenty of gifted credit through referral still its prompting me to buy plan after monthly 5$ reached.
