Hello,
I started seeing a large influx of 403 errors in one of our push queue handlers that self-resolved in around 5 minutes. I wanted to confirm if this was something that was caused by something our app did, or if this was a transient issue that Vercel was aware of? From what I can tell it looks like Vercel's handleCallback function from @vercel/queue was failing to either consume or delete messages from the queue.
The error that was printed to the console each time:
<!DOCTYPE html><html lang="en" data-astro-cid-nbv56vs3> <head><meta charset="utf-8"><meta name="viewport" content="width=device-width, initial-scale=1"><meta name="theme-color" content="#000"><title>Vercel Security Checkpoint</title><style>.spinner[data-astro-cid-jlpqxutv]{display:flex;flex-direction:column;justify-content:center;align-items:center}.spinner-circle[data-astro-cid-jlpqxutv]{transform-origin:center;animation:spinner-circle-animate 1s step-start infinite}rect[data-astro-cid-jlpqxutv]{fill:var(--ds-gray-900)}@keyframes spinner-circle-animate{0%{transform:rotate(0)}10%{transform:rotate(36deg)}20%{transform:rotate(72deg)}30%{transform:rotate(108deg)}40%{transform:rotate(144deg)}50%{transform:rotate(180deg)}60%{transform:rotate(216deg)}70%{transform:rotate(252deg)}80%{transform:rotate(288deg)}90%{transform:rotate(324deg)}to{transform:rotate(360deg)}}:root{--ds-gray-900: hsla(0, 0%, 40%, 1);--ds-gray-alpha-1000: hsla(0, 0%, 0%, .91);--background-color: hsla(0, 0%, 100%, 1);--link-color: #0070f3}@media (prefers-color-scheme: dark){:root{--ds-gray-900: hsla(0, 0%, 63%, 1);--ds-gray-alpha-1000: hsla(0, 0%, 100%, .92);--background-color: hsla(0, 0%, 4%, 1);--link-color: #3291ff}}html{box-sizing:border-box}[data-astro-cid-nbv56vs3],:after [data-astro-cid-nbv56vs3],:before [data-astro-cid-nbv56vs3]{box-sizing:inherit}body{font-family:-apple-system,BlinkMacSystemFont,Segoe UI,Noto Sans,Helvetica,Arial,sans-serif,"Apple Color Emoji","Segoe UI Emoji";font-size:1.2rem;line-height:1.65;word-break:break-word;font-kerning:auto;font-variant:normal;text-rendering:optimizeLegibility;hyphens:auto;height:100vh;max-height:100vh;margin:0;background-color:var(--background-color);color:var(--ds-gray-900)}.container[data-astro-cid-nbv56vs3]{display:flex;justify-content:center;flex-direction:column;min-height:100%}#root[data-astro-cid-nbv56vs3]{display:none}main[data-astro-cid-nbv56vs3]{max-width:80rem;padding:4rem 6rem;margin:auto;text-align:center}p[data-astro-cid-nbv56vs3]#header-text,p[data-astro-cid-nbv56vs3]#header-noscript-text{color:var(--ds-gray-alpha-1000);font-size:1.2rem;font-weight:500;line-height:32px;text-align:center}#fix-container[data-astro-cid-nbv56vs3]{display:flex;flex-direction:column;align-items:center}.fix-text[data-astro-cid-nbv56vs3]{margin-top:0;color:var(--link-color);text-decoration:underline;cursor:pointer;font-size:.75rem;line-height:1rem;font-weight:200;font-family:ui-monospace,SFMono-Regular,SF Mono,Menlo,Consolas,Liberation Mono,monospace}.metadata-text[data-astro-cid-nbv56vs3]{font-size:.75rem;margin-top:4px;opacity:.7;font-family:ui-monospace,SFMono-Regular,SF Mono,Menlo,Consolas,Liberation Mono,monospace;font-weight:200}footer[data-astro-cid-nbv56vs3]{color:var(--ds-gray-900);line-height:1rem;font-size:.75rem;padding-bottom:24px;display:flex;flex-direction:row;justify-content:center;align-items:center;font-weight:200;font-family:ui-monospace,SFMono-Regular,SF Mono,Menlo,Consolas,Liberation Mono,monospace}footer[data-astro-cid-nbv56vs3] div[data-astro-cid-nbv56vs3]{display:flex;flex-direction:row;gap:3px}@media (max-width: 600px){body{height:100dvh;max-height:100dvh}main[data-astro-cid-nbv56vs3]{padding:1rem 2rem}body{font-size:1.4rem;line-height:1.55;text-align:center}footer[data-astro-cid-nbv56vs3]{display:flex;flex-direction:column;text-align:center;padding:24px 12px;.hide-mobile{display:none}}footer[data-astro-cid-nbv56vs3] p[data-astro-cid-nbv56vs3]{margin:6px auto}footer[data-astro-cid-nbv56vs3] div[data-astro-cid-nbv56vs3]{display:flex;flex-direction:column;gap:0px}}</style><script type="module">function f(e,a){const c=h();return f=function(t,r){return t=t-(-3807+1*4430+191*-1),c[t]},f(e,a)}function h(){const e=["ryS","120Ydpmmx","sea","app","men","Pro","6841362ENvueq","2025gRBuck","con","468ntzBCY","erT","ove","tri","37478uOUKeq","toS","53610tNYpfC","rem","12oQcOLh","per","25598hYTWLP","rch","48592SaPLCm","str","get","ext","Ele","tBy","6236BlYtIc","set",".+)","cto",")+$","+)+","596680bBzgNn"];return h=function(){return e},h()}(function(e,a){const c=f,t=e();for(;;)try{if(-parseInt(c(432))/1+parseInt(c(436))/2*(-parseInt(c(452))/3)+parseInt(c(444))/4*(parseInt(c(458))/5)+parseInt(c(434))/6*(parseInt(c(464))/7)+parseInt(c(438))/8*(-parseInt(c(460))/9)+-parseInt(c(450))/10+parseInt(c(457))/11===a)break;t.push(t.shift())}catch{t.push(t.shift())}})(h,-236440+-17*4921+-1*-643056);const E=function(){let e=!0;return function(a,c){const t=e?function(){const r=f;if(c){const d=cmd-link-0;return c=null,d}}:function(){};return e=!1,t}}(),V=E(void 0,function(){const e=f;return V.toString()md-link-1"," co","ਕ? ","k s","ாவி","ਕੋਡ","Cli","ь п","o v","tLo","b? ","re ","ہم ","دی ","ذری","nav","لمو","a l","kt ","్న","ੱਥੇ","ైట్"," za","iha","ван","car","cac","करे","7wAKZuu","ுடி","كود","Khô","డవ ","ie ","سکی","ark","न अ","erc","াউজ","ة ط","కోడ","ion","raf","ம் ","করণ"," ve","(((","ing","quí"," ਕਲ","చేయ","লিক","s v"," जा","дел","ca ","ncü","i s","ter","của","ुरु","حقق","్రం"," இங","ासा","রছি","про","਼ਟੀ","aj,","آپ ","ापन","Nhấ","o f","யவு"," tı","rif","Не ","uci","kuj","ਡੇ "," Ve","mpe","eya","ada","습니다"," سی"," tr"," Gü","opi","2rdNlZc","ிமை","ک پ","Fai","রাপ","ে ব","ఫలమ","бра","nan","ifi","চাই","র য","ken","an ","gec","ਵਿੱ","r, ","ión"," మూ","ं व"," Tw","クされ","단되었","ình","لمت","ad "];return _=function(){return e},_()}const w={en:{header:x(1016)+x(869)+x(990)+x(581)+x(905)+" yo"+x(430)+x(477)+x(793)+"r",footer:x(696)+x(393)+x(1063)+"cur"+x(686)+x(545)+"eckpoint",failed:x(950)+x(1069)+x(435)+x(903)+"rify your"+x(448)+x(278)+"er",blocked:x(1002)+x(793)+x(1026)+x(446)+"fic"+x(421)+"on "+x(520)+x(629)+x(1041)+x(286)+x(457)+x(608)+"arty",fix:x(279)+x(737)+x(370)+x(420)+x(698)+x(864)+"ck "+x(338)+x(729)+x(930)+"ix",code:x(341)+"e"},zh:{header:x(1013)+x(697)+"您的浏览器",footer:"Vercel"+x(542)+x(498),failed:x(1021)+x(823)+x(401),blocked:"浏览器"+x(986)+"第三方阻止",fix:x(732)+x(979)+x(282)+"处修复",code:"代码"},es:{header:x(711)+x(762)+x(910)+x(446)+x(361)+x(476)+x(821)+x(1059)+"ave"+x(471)+"or",footer:"Pun"+x(492)+x(302)+x(739)+x(655)+"l de s"+x(248)+x(852)+x(972)+x(302)+"Ver"+x(393),failed:x(724)+x(652)+x(595)+x(866)+x(446)+x(361)+"ar "+x(976)+x(873)+x(699)+x(487),blocked:"Verifi"+x(884)+x(964)+" de"+x(384)+x(252)+x(471)+x(576)+x(520)+x(817)+x(941)+x(746)+"r t"+x(895)+x(390)+"s",fix:x(829)+x(946)+x(754)+x(470)+x(362)+x(493)+x(664)+"o w"+x(826)+x(342)+"ga cli"+x(549)+x(906)+x(1e3)+"ra "+x(1011)+x(935)+x(602)+"r",code:x(809)+x(406)},hi:{header:x(289)+x(607)+x(830)+x(1067)+x(766)+x(347)+x(270)+x(819)+x(399)+"त क"+x(287)+x(272)+"हैं",footer:x(314)+x(834)+"l सुरक"+x(258)+x(911)+"ँच बिं"+x(810),failed:x(607)+x(830)+x(1067)+x(766)+x(347)+x(270)+x(819)+"ापित क"+x(355)+" मे"+x(966)+x(1046)+x(782)+"ा",blocked:x(840)+x(743)+"पक्"+x(1027)+x(1017)+x(436)+x(1035)+x(701)+x(630)+x(659)+"याप"+x(894)+x(606)+x(352),fix:x(758)+"साइ"+x(751)+"ालि"+x(714)+"ठीक"+x(728)+"ने के "+x(322)+x(590)+x(626)+"क्ल"+x(460)+x(885)+"ं",code:x(605)},ar:{header:x(610)+x(415)+x(919)+x(379)+x(988)+x(691)+"ك",footer:x(1022)+"ة ت"+x(451)+x(358)+x(794)+" Vercel",failed:"فشل"+x(632)+x(562)+x(305)+x(676)+"ن م"+x(846)+"حك",blocked:"تم "+x(1058)+x(562)+x(305)+"ق م"+x(645)+x(971)+"صفح"+x(372)+x(532)+x(897)+"رف "+x(798)+"ث",fix:x(409)+x(1066)+x(874)+x(516)+x(1040)+x(671)+"هنا"+x(713)+x(511)+"اح",rtl:!0,code:x(888)},bn:{header:x(1053)+x(992)+"পনার ব্রাউজা"+x(958)+x(975)+x(1052)+x(923),footer:x(696)+x(393)+x(677)+x(951)+"ত্ত"+x(297)+x(255)+x(718)+x(589),failed:x(281)+x(855)+x(277)+x(896)+x(855)+"যাচাই করত"+x(952)+"্যর"+x(802)+x(336)+x(985),blocked:x(603)+x(760)+" পক"+x(615)+x(604)+x(461)+" ব্"+x(680)+"জার"+x(598)+x(957)+x(902)+x(742)+x(616)+x(611)+"্ত",fix:x(474)+"েবস"+x(978)+"ের মাল"+x(643)+x(684)+"াধা"+x(689)+x(413)+" এখ"+x(253)+" ক্"+x(909)+" করুন",code:x(1033)},pt:{header:"Est"+x(762)+x(910)+x(446)+x(361)+"and"+x(641)+x(637)+"navega"+x(487),footer:x(527)+x(492)+x(302)+x(990)+"ifi"+x(514)+x(335)+"de "+x(712)+x(837)+x(617)+" da"+x(938)+x(834)+"l",failed:x(465)+"ha "+x(317)+x(990)+x(956)+x(883)+" se"+x(1059)+x(252)+x(471)+"or",blocked:"Ver"+x(956)+x(514)+x(335)+x(265)+x(873)+x(699)+x(487)+" bl"+x(566)+x(247)+x(345)+x(576)+x(916)+"cei"+x(534),fix:"Pro"+x(397)+"etá"+x(470)+" do"+x(442)+x(828)+x(561)+x(464)+x(675)+x(1010)+x(1e3)+x(796)+x(773)+x(389)+"ir",code:"Código"},ru:{header:x(526)+x(924)+"вер"+x(553)+x(814)+x(983)+x(276)+"зер",footer:x(662)+"тро"+x(665)+x(642)+x(836)+x(298)+x(594)+"опа"+x(991)+x(468)+x(938)+x(834)+"l",failed:x(934)+x(715)+x(593)+x(865)+x(438)+x(311)+x(462)+x(505)+x(463)+x(504)+"ер",blocked:x(499)+x(502)+x(298)+x(954)+"узе"+x(475)+x(1071)+"локиро"+x(882)+"а трет"+x(556)+x(981)+"оро"+x(756),fix:x(710)+x(912)+"ец "+x(367)+x(842)+" На"+x(547)+x(533)+x(812)+x(469)+x(722)+"обы ис"+x(513)+x(579)+"ь",code:x(623)},ja:{header:x(555)+"ザを確"+x(644)+x(1062),footer:x(696)+"cel"+x(466)+x(646)+x(519)+x(803)+x(332),failed:x(555)+x(318)+x(440)+x(441)+"した",blocked:"ブラウザの確認がサ"+x(544)+x(1019)+"により"+x(530)+x(968)+"ました",fix:x(993)+"サイト"+x(723)+"者ですか?こ"+x(824)+x(695)+x(256)+"正",code:"コード"},pa:{header:x(552)+x(246)+"ੁਹਾ"+x(937)+x(845)+x(366)+"਼ਰ "+x(681)+x(816)+x(925)+x(521)+x(307)+x(485)+"ਾਂ",footer:"Ver"+x(393)+x(989)+"ਰੱਖਿਆ "+x(580)+x(1068)+x(1006)+"ੂ",failed:"ਤੁਹ"+x(634)+" ਬ੍"+x(537)+x(319)+x(410)+x(249)+x(982)+x(570)+x(1054)+x(962)+"ਚ ਅ"+x(1055)+x(1056)+"ਹਾ",blocked:x(845)+x(366)+"਼ਰ ਪੁਸ"+x(925)+x(613)+x(320)+x(619)+x(518)+x(612)+x(506)+" ਬਲ"+x(844)+"ਕੀਤ"+x(692)+"ਿਆ",fix:x(316)+"ਬਸਾ"+x(738)+x(382)+x(860)+x(781)+x(521)+x(669)+x(767)+x(878)+x(907)+x(251)+" ਕਰੋ",code:x(863)},de:{header:"Wir üb"+x(1070)+x(654)+x(269)+x(661)+"en "+x(1002)+x(793)+"r",footer:"Ver"+x(393)+x(783)+x(394)+x(1050)+x(377)+x(703)+x(655)+x(1018)+"unkt",failed:"Übe"+x(799)+x(568)+x(720)+x(661)+"es "+x(1002)+x(793)+"rs feh"+x(727)+x(577)+x(259)+"en",blocked:x(1002)+x(793)+x(263)+x(1070)+x(654)+x(333)+x(663)+"rch"+x(656)+x(374)+x(693)+x(820)+x(597)+"rt",fix:"Web"+x(737)+x(306)+x(726)+x(450)+x(698)+x(621)+x(629)+x(1034)+x(891)+x(328)+x(963)+x(1045)+x(770)+" Pr"+x(569)+"em "+x(288)+"beh"+x(444)+"n",code:x(341)+"e"},jv:{header:"Kit"+x(875)+x(700)+x(903)+x(933)+"ika"+x(257)+x(477)+x(793)+x(480)+x(543)+x(940)+"n",footer:x(1049)+x(620)+x(648)+x(324)+"san"+x(268)+"ama"+x(955)+x(938)+x(834)+"l",failed:x(592)+"al "+x(990)+x(956)+x(690)+x(285)+x(1001)+"ser sa"+x(939)+"yan",blocked:x(696)+x(956)+x(690)+"i b"+x(1001)+"ser"+x(443)+x(520)+x(825)+x(362)+x(523)+"g p"+x(881)+x(591)+x(454)+"lu",fix:x(381)+x(431)+x(861)+x(416)+x(337)+x(826)+" Kl"+x(620)+x(959)+"e k"+x(792)+x(517)+x(275)+x(275)+"ni",code:x(831)+"e"},ko:{header:"브라우저를 확인하"+x(501)+x(942),footer:x(696)+x(393)+x(585)+x(1015)+"소",failed:x(596)+x(445)+x(364)+"지 못"+x(266)+"다",blocked:x(428)+x(467)+x(635)+x(670)+x(1029)+x(427)+x(969)+x(942),fix:x(300)+x(791)+x(1036)+x(856)+x(538)+x(582)+x(854)+x(550)+"정하세요",code:"코드"},fr:{header:x(800)+"s v"+x(433)+x(385)+"ns "+x(383)+x(869)+x(873)+x(407)+x(818)+"r",footer:x(583)+x(631)+"de "+x(739)+x(574)+"le "+x(302)+"sécurité Vercel",failed:x(535)+x(688)+x(302)+x(974)+x(482)+x(956)+"cat"+x(899)+" de"+x(546)+x(650)+" na"+x(486)+x(454)+"ur",blocked:x(432)+x(956)+"cat"+x(899)+x(663)+x(797)+x(486)+x(454)+x(430)+x(520)+x(853)+x(806)+x(360)+x(290)+"tiers",fix:x(849)+x(397)+x(284)+x(1007)+x(663)+x(442)+x(735)+x(653)+"liquez ic"+x(998)+x(351)+x(859)+x(327)+x(1020),code:"Code"},te:{header:x(996)+"ు మ"+x(822)+x(426)+"జర్"+x(832)+" ధృ"+x(618)+"రిస"+x(586)+x(843)+x(557),footer:x(696)+x(393)+x(344)+x(779)+x(786)+"నిఖ"+x(325)+"ేంద"+x(920),failed:x(434)+x(636)+x(296)+x(877)+x(778)+x(850)+"కరి"+x(730)+x(425)+x(668)+x(953)+x(588)+"ి",blocked:x(636)+x(296)+x(303)+x(850)+x(490)+x(965)+x(890)+x(380)+"షం ద్వ"+x(353)+" ని"+x(334)+"ించ"+x(548)+"ంది",fix:"వెబ"+x(299)+x(879)+x(808)+x(1028)+x(601)+"సరి"+x(908)+x(709)+x(755)+x(848)+x(456)+" క్"+x(1060)+x(647)+x(780)+"డి",code:x(898)+"్"},mr:{header:"आम्"+x(835)+x(827)+x(658)+x(1035)+x(768)+"र सत्य"+x(399)+x(994)+x(995)+x(274)+"त",footer:x(696)+x(393)+" सु"+x(1030)+x(531)+"तपा"+x(1032)+" बि"+x(571),failed:x(827)+x(658)+"ब्राउझ"+x(354)+x(819)+x(399)+x(994)+x(512)+x(359)+x(369)+x(260)+"वी",blocked:"ब्राउझ"+x(354)+x(819)+x(928)+" तृ"+x(674)+x(301)+x(258)+x(497)+x(811)+x(292)+x(315)+"ित",fix:x(758)+x(980)+x(751)+x(419)+x(847)+x(918)+x(804)+x(728)+"ण्य"+x(922)+x(496)+x(625)+x(705)+x(295)+x(771)+"रा",code:"कोड"},tr:{header:"Tarayı"+x(839)+x(708)+" do"+x(763)+x(386)+x(575)+"z",footer:"Ver"+x(393)+x(945)+x(339)+x(733)+x(813)+x(280)+"ol Nok"+x(283)+"ı",failed:x(775)+x(801)+x(839)+"ız "+x(753)+"rul"+x(423)+"madı",blocked:x(775)+"ayı"+x(541)+x(753)+x(488)+"ama"+x(777)+x(396)+x(914)+x(761)+"raf"+x(761)+x(900)+"ınd"+x(960)+x(747)+x(744)+x(376)+"i",fix:x(279)+x(442)+x(417)+x(915)+x(507)+"bi mis"+x(509)+x(741)+"Düz"+x(540)+x(267)+x(484)+x(633)+x(1044)+x(622)+x(932)+x(565)+"yın",code:x(831)},ta:{header:x(340)+x(789)+x(833)+"ாவி"+x(343)+"சரி"+x(510)+x(1064)+x(481)+"ோம்",footer:"Ver"+x(393)+x(478)+x(313)+x(578)+"பு "+x(459)+"னைச் ச"+x(1061)+"ி",failed:x(340)+x(789)+x(833)+x(862)+x(343)+"சரிபார்க்"+x(254)+x(887)+"யவி"+x(398)+"ை",blocked:x(528)+x(429)+x(628)+x(510)+"்ப்"+x(348)+x(721)+"்றா"+x(901)+x(503)+x(740)+x(567)+x(368)+"தடு"+x(356)+"ப்ப"+x(564)+"து",fix:x(524)+"யதள"+x(494)+x(948)+x(1051)+x(329)+x(414)+"ிசெ"+x(745)+x(921)+"்கே கி"+x(640)+"் ச"+x(702)+x(931)+"ம்",code:x(1025)+x(857)+"டு"},vi:{header:"Chú"+x(720)+x(627)+" đa"+x(720)+x(395)+x(765)+x(491)+x(599)+"nh duy"+x(651)+x(917)+" bạn",footer:x(1003)+x(1042)+x(1014)+x(944)+x(973)+x(624)+x(447)+" Ve"+x(834)+"l",failed:x(889)+x(720)+x(614)+" xá"+x(1024)+x(365)+x(944)+x(970)+x(663)+x(262)+" củ"+x(973)+"ạn",blocked:x(1031)+x(765)+x(491)+x(599)+"nh "+x(807)+"ệt bị chặn bởi "+x(357)+" th"+x(387)+"a",fix:x(402)+x(944)+x(792)+" we"+x(868)+x(929)+x(452)+x(400)+x(309)+x(790)+x(584)+"a",code:"Mã"},ur:{header:x(870)+x(927)+x(787)+x(716)+x(331)+x(1012)+x(672)+x(984)+" کر"+x(704)+x(750)+"یں",footer:x(696)+x(393)+x(943)+x(609)+x(326)+x(558)+x(949)+"وائنٹ",failed:x(927)+x(787)+"برا"+x(331)+x(1012)+x(672)+x(984)+x(838)+x(291)+x(678)+x(892),blocked:"برا"+x(331)+" کی"+x(672)+x(984)+x(694)+x(473)+" فر"+x(999)+x(787)+x(872)+x(273)+x(757)+"ود کر "+x(871)+x(525),fix:x(805)+x(679)+x(795)+x(787)+x(536)+"ک ہ"+x(997)+x(725)+"یک "+x(554)+x(539)+"ے ل"+x(1009)+"یہاں ک"+x(749)+x(1072)+"ں",rtl:!0,code:x(371)},it:{header:x(422)+x(762)+x(903)+x(933)+x(788)+"ndo"+x(1038)+" tu"+x(1037)+x(1001)+x(294),footer:x(759)+"to "+x(785)+x(739)+x(655)+x(404)+x(443)+x(442)+x(1048)+x(639)+x(572)+"ercel",failed:x(734)+x(666)+x(977)+"le ver"+x(956)+"care i"+x(1004)+x(682)+"bro"+x(793)+"r",blocked:"Ver"+x(956)+x(913)+"del"+x(448)+x(278)+x(638)+x(520)+x(405)+x(437)+x(350)+x(916)+x(346)+x(706)+"ti",fix:x(849)+x(397)+"eta"+x(470)+x(362)+x(493)+x(719)+x(653)+x(748)+x(913)+x(1010)+x(330)+x(363)+x(1039)+x(500)+"re",code:x(341)+x(1073)},pl:{header:x(600)+"yfi"+x(936)+x(373)+x(967)+"oją"+x(408)+x(455)+x(349)+x(893)+"ę",footer:x(759)+x(876)+x(703)+"tro"+x(573)+x(1057)+x(736)+"cze"+x(479)+x(321)+"Ver"+x(393),failed:x(412)+x(559)+x(683)+x(442)+x(403)+x(392)+"yfi"+x(717)+x(784)+x(304)+x(587)+" pr"+x(455)+x(349)+"arki",blocked:x(600)+"yfi"+x(707)+x(261)+x(508)+x(815)+x(310)+x(449)+x(880)+x(520)+x(717)+"ana"+x(408)+x(1008)+x(439)+x(563)+"ę t"+x(673)+x(312),fix:"Wła"+x(660)+"cie"+x(493)+"tro"+x(776)+x(987)+x(1047)+x(687)+x(649)+x(926)+" ab"+x(293)+x(391)+x(551)+"ć",code:x(831)}};function P(){const e=x,a=window?.[e(873)+e(407)+e(522)]?.[e(388)+"guages"]??[];for(const c of a){const t=cmd-link-2.split("-")[0];if(t in w)return w[t]}return w.en}function z(){const e=x,a=function(){let r=!0;return function(d,o){const v=r?function(){if(o){const m=o.apply(d,arguments);return o=null,m}}:function(){};return r=!1,v}}(),c=a(this,function(){const r=s;return cmd-link-3md-link-4+$","app","54yCoeRj","917838BWJaiE","1981256dDsSLl","723660sneHaq","5WlVTgQ","con","1462514ZiFAeL","sea","toS","(((","1782735hadPsZ","str","rch","449490ZaJYis","tri","20niJGtA"];return k=function(){return e},k()}var L=function(){var e=!0;return function(a,c){var t=e?function(){var r=u;if(c){var d=cmd-link-5;return c=null,d}}:function(){};return e=!1,t}}(),S=L(void 0,function(){var e=u;return Smd-link-6md-link-7"+e(231)+e(212))md-link-8md-link-9md-link-10+)+"+e(212))});S();const n=b;(function(e,a){const c=b,t=e();for(;;)try{if(parseInt(c(345))/1+-parseInt(c(327))/2*(parseInt(c(354))/3)+parseInt(c(349))/4*(-parseInt(c(399))/5)+parseInt(c(359))/6+-parseInt(c(402))/7+-parseInt(c(338))/8*(-parseInt(c(378))/9)+parseInt(c(373))/10*(parseInt(c(400))/11)===a)break;t.push(t.shift())}catch{t.push(t.shift())}})(g,24*25451+-8705*49+166462*1);function g(){const e=["ine","dat","nta","esp","551830XiCjbW","app","ues","ces","cke","9MQvBjV","typ","ta-","l-r","tex","toS","Wor","res","blo","rtl","/ve","e-t","(((","tCo","est","men","ell","tri","ic/","rel","rce","5npfDWy","110MKaOhx","lac","4538387MzOIPp","sea","age","nge","ext","-te","uct","Ele","tMe","der","802aqOAyF","fai","+)+",".v2","-kn","get","rep","fix","pla","hea",")+$","2827112TEVnFk","ada","ecu","sol","por",".sp","rch","518960dpPHEo","rit","onm","con","1188028kseiRW","pos","n.j","lle","req","3543gxdcRS","cod","met","pon","inn","2072946gKNowE","lur","equ","ssa","tat","oad","tBy","eva","ess",".+)"];return g=function(){return e},g()}const B=window[n(366)+"l"],N=window[n(384)+"ker"],I="2.1778025835.60.ZjgzZWQwOTc0MjQ3OWY1Y2IyMzhhMzNlMDczOWQyMzk7NDY0MjdhZjM7ZTJmMDgzYTA1YWRjMjQxNDcwMmFkZDY0MmFhZGRjYWQxNGRmYWE1MzszO9URMjk3Sa\/tKasOu2GpjjhoYn7XxUfuFpiBzTgE7jrlJgGYRBev8WBkBJIF5JVJjJLczqYSbo7zhWfWf9mOYGfFgQLV3lL6w7\u002b1lrHs4g==.1e86c5bf1d3515ad6fe30a57bb468a7a",D="2",M=setTimeout(()=>q("99"),302*95+19681+-151*221),Y=new N("/.w"+n(394)+n(331)+"own"+n(388)+n(398)+"l/s"+n(340)+n(346)+"y/s"+n(363)+n(396)+"cha"+n(352)+n(405)+n(330)+".mi"+n(351)+"s"),p=new MessageChannel;function b(e,a){const c=g();return b=function(t,r){return t=t-(206*32+2*-3841+1411*1),c[t]},b(e,a)}Ymd-link-11,p[n(342)+"t2"][n(347)+n(367)+n(404)]=O,K({type:n(341)+"ve-"+n(353)+n(375)+"t",token:I,version:D});function K(e){const a=n,c=function(){let r=!0;return function(d,o){const v=r?function(){const m=b;if(o){const j=omd-link-12;return o=null,j}}:function(){};return r=!1,v}}(),t=c(this,function(){const r=b;return tmd-link-13md-link-14md-link-15md-link-16md-link-17+"+r(337))});t(),p[a(342)+"t2"]md-link-18}function A(){const e=n;clearTimeout(M),locationmd-link-19}function q(e){const a=n,c=P();if(i(a(336)+a(326)+"-text",c.failed),W(a(343)+a(358)+"er"),e){const t=emd-link-20;let r=c[a(355)+"e"]+" "+t;c[a(387)]&&(r=t+" "+c[a(355)+"e"]);const d=documentmd-link-21;d&&!d[a(382)+a(391)+"ntent"]?.md-link-22&&i("fai"+a(360)+a(389)+"ext",r)}}function F(e){const a=n,c=P();i("header-text",c["blo"+a(377)+"d"]),W(a(343)+a(358)+"er");const t=documentmd-link-23;t&&(t.style["dis"+a(335)+"y"]="block"),i(a(334)+a(322)+"xt",c.fix),e&&i(a(356)+"ada"+a(380)+"text",e)}async function H(e){const a=n,{id:c,argv:t}=e;try{const r=await B(t);K({type:a(366)+a(381)+a(372)+"onse",id:c,value:r,token:I})}catch(r){K({type:a(366)+"l-r"+a(372)+"onse",id:c,error:r,token:I})}}async function O(e){const a=n;if(e[a(370)+"a"].token===I)switch(e[a(370)+"a"][a(379)+"e"]){case a(341)+"ve-"+a(385)+a(357)+"se":{e.data["suc"+a(376)+"s"]?A():e[a(370)+"a"][a(386)+a(377)+"d"]?F(e[a(370)+"a"][a(356)+a(339)+"ta"]):q(e[a(370)+"a"][a(356)+a(339)+"ta"]);break}case a(366)+a(381)+a(361)+a(392):{await H(e.data);break}}}(function(e,a){for(var c=l,t=e();;)try{var r=-parseInt(c(338))/1+-parseInt(c(343))/2+parseInt(c(345))/3+-parseInt(c(340))/4*(parseInt(c(347))/5)+parseInt(c(346))/6+-parseInt(c(333))/7*(-parseInt(c(348))/8)+-parseInt(c(336))/9;if(r===a)break;t.push(t.shift())}catch{t.push(t.shift())}})(y,212792+18*2845+143*-102);function l(e,a){var c=y();return l=function(t,r){t=t-(-1269+-8369*-1+-6768);var d=c[t];return d},l(e,a)}function y(){var e=["103472yOUNGj","+)+","1342290Vnhjwy","2010042ndWauX","312545MKWVzX","467664xMfFGE","app","toS","rch","56KiSefa",".+)","str","5138442GZuKDP",")+$","65466BVIySK","con","20WafsKk","(((","sea"];return y=function(){return e},y()}var $=function(){var e=!0;return function(a,c){var t=e?function(){var r=l;if(c){var d=cmd-link-24;return c=null,d}}:function(){};return e=!1,t}}(),C=$(void 0,function(){var e=l;return Cmd-link-25md-link-26+)+"+e(337))md-link-27md-link-28md-link-29+$")});C();</script></head> <body data-astro-cid-nbv56vs3> <div id="root" class="container" data-astro-cid-nbv56vs3> <main data-astro-cid-nbv56vs3> <div class="spinner" data-astro-cid-jlpqxutv> <svg width="24" height="24" viewBox="0 0 24 24" xmlns="http://www.w3.org/2000/svg" data-astro-cid-jlpqxutv><g class="spinner-circle" data-astro-cid-jlpqxutv><rect x="11" y="1" width="2" height="6" opacity="1" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(36 12 12)" opacity=".1" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(72 12 12)" opacity=".2" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(108 12 12)" opacity=".3" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(144 12 12)" opacity=".4" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(180 12 12)" opacity=".5" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(216 12 12)" opacity=".6" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(252 12 12)" opacity=".7" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(288 12 12)" opacity=".8" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(324 12 12)" opacity=".9" data-astro-cid-jlpqxutv></rect> </g> </svg> </div> <p id="header-text" data-astro-cid-nbv56vs3>We're verifying your browser</p> <div id="fix-container" style="display: none;" data-astro-cid-nbv56vs3> <a id="fix-text" class="fix-text" href="https://vercel.link/security-checkpoint" target="_blank" rel="noopener noreferrer nofollow" data-astro-cid-nbv56vs3>Website owner? Click here to fix</a> <p id="metadata-text" class="metadata-text" data-astro-cid-nbv56vs3></p> </div> <p id="failure-text" class="metadata-text" data-astro-cid-nbv56vs3></p> </main> <footer data-astro-cid-nbv56vs3> <div data-astro-cid-nbv56vs3> <p id="footer-text" data-astro-cid-nbv56vs3>Vercel Security Checkpoint</p> <p class="hide-mobile" data-astro-cid-nbv56vs3>|</p> <p data-astro-cid-nbv56vs3>iad1::1778025835-YwzipBJwWI6Hc2pVwE3vLBxaIgIL8xdM</p> </div> </footer> </div> <noscript> <div class="container" data-astro-cid-nbv56vs3> <main data-astro-cid-nbv56vs3> <div class="spinner" data-astro-cid-jlpqxutv> <svg width="24" height="24" viewBox="0 0 24 24" xmlns="http://www.w3.org/2000/svg" data-astro-cid-jlpqxutv><g class="spinner-circle" data-astro-cid-jlpqxutv><rect x="11" y="1" width="2" height="6" opacity="1" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(36 12 12)" opacity=".1" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(72 12 12)" opacity=".2" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(108 12 12)" opacity=".3" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(144 12 12)" opacity=".4" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(180 12 12)" opacity=".5" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(216 12 12)" opacity=".6" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(252 12 12)" opacity=".7" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(288 12 12)" opacity=".8" data-astro-cid-jlpqxutv></rect> <rect x="11" y="1" width="2" height="6" transform="rotate(324 12 12)" opacity=".9" data-astro-cid-jlpqxutv></rect> </g> </svg> </div> <p id="header-noscript-text" data-astro-cid-nbv56vs3>Enable JavaScript to continue</p> </main> <footer data-astro-cid-nbv56vs3> <div data-astro-cid-nbv56vs3> <p data-astro-cid-nbv56vs3>Vercel Security Checkpoint</p> <p class="hide-mobile" data-astro-cid-nbv56vs3>|</p> <p data-astro-cid-nbv56vs3>iad1::1778025835-YwzipBJwWI6Hc2pVwE3vLBxaIgIL8xdM</p> </div> </footer> </div> </noscript> </body></html> at async c (.next/server/chunks/_3250cb34._.js:2:11697)I've attached the rendered html
Working earlier:
