Checking tracert to 216.198.79.1
├─────── Testing 216.198.79.65
Checking headers via 216.198.79.65
- Connecting to hostname: 216.198.79.65
- Trying 216.198.79.65:443...
- Connected to 216.198.79.65 (216.198.79.65) port 443
- ALPN: curl offers h2,http/1.1
} [5 bytes data]
- TLSv1.3 (OUT), TLS handshake, Client hello (1):
} [512 bytes data]
- TLSv1.3 (IN), TLS handshake, Server hello (2):
{ [122 bytes data]
- TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
{ [19 bytes data]
- TLSv1.3 (IN), TLS handshake, Certificate (11):
{ [2573 bytes data]
- TLSv1.3 (IN), TLS handshake, CERT verify (15):
{ [264 bytes data]
- TLSv1.3 (IN), TLS handshake, Finished (20):
{ [36 bytes data]
- TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
} [1 bytes data]
- TLSv1.3 (OUT), TLS handshake, Finished (20):
} [36 bytes data]
- SSL connection using TLSv1.3 / TLS_AES_128_GCM_SHA256 / X25519 / RSASSA-PSS
- ALPN: server accepted h2
- Server certificate:
- subject: CN=recuida.com
- start date: Apr 15 23:05:04 2026 GMT
- expire date: Jul 14 23:05:03 2026 GMT
- issuer: C=US; O=Let's Encrypt; CN=R13
- SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
- Certificate level 0: Public key type RSA (2048/112 Bits/secBits), signed using sha256WithRSAEncryption
- Certificate level 1: Public key type RSA (2048/112 Bits/secBits), signed using sha256WithRSAEncryption
{ [5 bytes data]
- TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
{ [122 bytes data]
- using HTTP/2
- [HTTP/2] [1] OPENED stream for https://recuida.com/
- [HTTP/2] [1] [:method: GET]
- [HTTP/2] [1] [:scheme: https]
- [HTTP/2] [1] [:authority: recuida.com]
- [HTTP/2] [1] [:path: /]
- [HTTP/2] [1] [user-agent: curl/8.5.0]
- [HTTP/2] [1] [accept: /]
} [5 bytes data]
GET / HTTP/2
Host: recuida.com
User-Agent: curl/8.5.0
Accept: /
{ [5 bytes data]
< HTTP/2 200
< accept-ranges: bytes
< access-control-allow-origin: *
< age: 204279
< cache-control: public, max-age=0, must-revalidate
< content-disposition: inline
< content-type: text/html; charset=utf-8
< date: Thu, 30 Apr 2026 00:58:44 GMT
< etag: "be42f8a10d39b47e381768dc2cdf8eef"
< server: Vercel
< strict-transport-security: max-age=63072000
< vary: rsc, next-router-state-tree, next-router-prefetch, next-router-segment-prefetch
< x-matched-path: /
< x-nextjs-prerender: 1
< x-nextjs-stale-time: 300
< x-vercel-cache: HIT
< x-vercel-id: gru1::2pt9x-1777510724034-3ad9dd5de99e
< content-length: 94910
{ [3148 bytes data]
- Connection #0 to host 216.198.79.65 left intact
Checking ping to 216.198.79.65
PING 216.198.79.65 (216.198.79.65) 56(84) bytes of data.
64 bytes from 216.198.79.65: icmp_seq=1 ttl=246 time=6.41 ms
64 bytes from 216.198.79.65: icmp_seq=2 ttl=246 time=5.35 ms
64 bytes from 216.198.79.65: icmp_seq=3 ttl=246 time=5.27 ms
64 bytes from 216.198.79.65: icmp_seq=4 ttl=246 time=4.87 ms
--- 216.198.79.65 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3031ms
rtt min/avg/max/mdev = 4.866/5.473/6.410/0.570 ms
├─────── Testing 216.198.79.129
Checking headers via 216.198.79.129
- Connecting to hostname: 216.198.79.129
- Trying 216.198.79.129:443...
- Connected to 216.198.79.129 (216.198.79.129) port 443
} [5 bytes data]
} [512 bytes data]
{ [122 bytes data]
{ [19 bytes data]
{ [2573 bytes data]
{ [264 bytes data]
{ [36 bytes data]
} [1 bytes data]
} [36 bytes data]
{ [5 bytes data]
{ [122 bytes data]
- using HTTP/2
} [5 bytes data]
GET / HTTP/2
Host: recuida.com
Accept: /
{ [5 bytes data]
< HTTP/2 200
< age: 204283
< date: Thu, 30 Apr 2026 00:58:47 GMT
< server: Vercel
< x-matched-path: /
< x-vercel-id: gru1::xsplv-1777510727578-93e8d844e875
{ [5 bytes data]
- Connection #0 to host 216.198.79.129 left intact
Checking ping to 216.198.79.129
PING 216.198.79.129 (216.198.79.129) 56(84) bytes of data.
64 bytes from 216.198.79.129: icmp_seq=1 ttl=246 time=5.31 ms
64 bytes from 216.198.79.129: icmp_seq=3 ttl=246 time=5.02 ms
64 bytes from 216.198.79.129: icmp_seq=4 ttl=246 time=5.42 ms
--- 216.198.79.129 ping statistics ---
4 packets transmitted, 3 received, 25% packet loss, time 3019ms
rtt min/avg/max/mdev = 5.021/5.247/5.416/0.166 ms
├─────── Testing 216.198.79.193
Checking headers via 216.198.79.193
- Connecting to hostname: 216.198.79.193
- Trying 216.198.79.193:443...
- Connected to 216.198.79.193 (216.198.79.193) port 443
} [5 bytes data]
} [512 bytes data]
{ [122 bytes data]
{ [19 bytes data]
{ [2573 bytes data]
{ [264 bytes data]
{ [36 bytes data]
} [1 bytes data]
} [36 bytes data]
{ [5 bytes data]
{ [122 bytes data]
- using HTTP/2
} [5 bytes data]
GET / HTTP/2
Host: recuida.com
Accept: /
{ [5 bytes data]
< HTTP/2 200
< age: 204287
< date: Thu, 30 Apr 2026 00:58:51 GMT
< server: Vercel
< x-matched-path: /
< x-vercel-id: gru1::h8mcx-1777510731715-7973e3ec1acc
{ [5 bytes data]
- Connection #0 to host 216.198.79.193 left intact
Checking ping to 216.198.79.193
PING 216.198.79.193 (216.198.79.193) 56(84) bytes of data.
64 bytes from 216.198.79.193: icmp_seq=1 ttl=246 time=7.58 ms
64 bytes from 216.198.79.193: icmp_seq=3 ttl=246 time=6.46 ms
64 bytes from 216.198.79.193: icmp_seq=4 ttl=246 time=6.13 ms
--- 216.198.79.193 ping statistics ---
4 packets transmitted, 3 received, 25% packet loss, time 3033ms
rtt min/avg/max/mdev = 6.125/6.722/7.583/0.623 ms
├─────── Testing 64.29.17.1
Checking headers via 64.29.17.1
- Connecting to hostname: 64.29.17.1
- Trying 64.29.17.1:443...
- Connected to 64.29.17.1 (64.29.17.1) port 443
} [5 bytes data]
} [512 bytes data]
{ [122 bytes data]
{ [19 bytes data]
{ [2573 bytes data]
{ [264 bytes data]
{ [36 bytes data]
} [1 bytes data]
} [36 bytes data]
{ [5 bytes data]
{ [122 bytes data]
- using HTTP/2
} [5 bytes data]
GET / HTTP/2
Host: recuida.com
Accept: /
{ [5 bytes data]
< HTTP/2 200
< age: 204291
< date: Thu, 30 Apr 2026 00:58:55 GMT
< server: Vercel
< x-matched-path: /
< x-vercel-id: gru1::n9774-1777510735841-eff052833297
{ [3146 bytes data]
- Connection #0 to host 64.29.17.1 left intact
Checking ping to 64.29.17.1
PING 64.29.17.1 (64.29.17.1) 56(84) bytes of data.
64 bytes from 64.29.17.1: icmp_seq=1 ttl=246 time=5.43 ms
64 bytes from 64.29.17.1: icmp_seq=2 ttl=246 time=9.98 ms
64 bytes from 64.29.17.1: icmp_seq=3 ttl=246 time=5.18 ms
64 bytes from 64.29.17.1: icmp_seq=4 ttl=246 time=4.98 ms
--- 64.29.17.1 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3003ms
rtt min/avg/max/mdev = 4.980/6.391/9.976/2.075 ms
├─────── Testing 64.29.17.65
Checking headers via 64.29.17.65
- Connecting to hostname: 64.29.17.65
- Trying 64.29.17.65:443...
- Connected to 64.29.17.65 (64.29.17.65) port 443
} [5 bytes data]
} [512 bytes data]
{ [122 bytes data]
{ [19 bytes data]
{ [2573 bytes data]
{ [264 bytes data]
{ [36 bytes data]
} [1 bytes data]
} [36 bytes data]
{ [5 bytes data]
{ [122 bytes data]
- using HTTP/2
} [5 bytes data]
GET / HTTP/2
Host: recuida.com
Accept: /
{ [5 bytes data]
< HTTP/2 200
< age: 204294
< date: Thu, 30 Apr 2026 00:58:59 GMT
< server: Vercel
< x-matched-path: /
< x-vercel-id: gru1::274s5-1777510739192-2c56fe4f2da4
{ [1 bytes data]
- Connection #0 to host 64.29.17.65 left intact
Checking ping to 64.29.17.65
PING 64.29.17.65 (64.29.17.65) 56(84) bytes of data.
64 bytes from 64.29.17.65: icmp_seq=1 ttl=246 time=6.10 ms
64 bytes from 64.29.17.65: icmp_seq=2 ttl=246 time=4.72 ms
64 bytes from 64.29.17.65: icmp_seq=3 ttl=246 time=4.78 ms
64 bytes from 64.29.17.65: icmp_seq=4 ttl=246 time=5.39 ms
--- 64.29.17.65 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3000ms
rtt min/avg/max/mdev = 4.724/5.248/6.102/0.558 ms
├─────── Testing 64.29.17.129
Checking headers via 64.29.17.129
- Connecting to hostname: 64.29.17.129
- Trying 64.29.17.129:443...
- Connected to 64.29.17.129 (64.29.17.129) port 443
} [5 bytes data]
} [512 bytes data]
{ [122 bytes data]
{ [19 bytes data]
{ [2573 bytes data]
{ [264 bytes data]
{ [36 bytes data]
} [1 bytes data]
} [36 bytes data]
{ [5 bytes data]
{ [122 bytes data]
- using HTTP/2
} [5 bytes data]
GET / HTTP/2
Host: recuida.com
Accept: /
{ [5 bytes data]
< HTTP/2 200
< age: 204298
< date: Thu, 30 Apr 2026 00:59:02 GMT
< server: Vercel
< x-matched-path: /
< x-vercel-id: gru1::cmffc-1777510742563-b2b2fc30cad8
{ [5 bytes data]
- Connection #0 to host 64.29.17.129 left intact
Checking ping to 64.29.17.129
PING 64.29.17.129 (64.29.17.129) 56(84) bytes of data.
64 bytes from 64.29.17.129: icmp_seq=1 ttl=246 time=6.71 ms
64 bytes from 64.29.17.129: icmp_seq=2 ttl=246 time=4.76 ms
64 bytes from 64.29.17.129: icmp_seq=3 ttl=246 time=4.79 ms
--- 64.29.17.129 ping statistics ---
4 packets transmitted, 3 received, 25% packet loss, time 2997ms
rtt min/avg/max/mdev = 4.759/5.419/6.712/0.914 ms
├─────── Testing 64.29.17.193
Checking headers via 64.29.17.193
- Connecting to hostname: 64.29.17.193
- Trying 64.29.17.193:443...
- Connected to 64.29.17.193 (64.29.17.193) port 443
} [5 bytes data]
} [512 bytes data]
{ [122 bytes data]
{ [19 bytes data]
{ [2573 bytes data]
{ [264 bytes data]
{ [36 bytes data]
} [1 bytes data]
} [36 bytes data]
{ [5 bytes data]
{ [122 bytes data]
- using HTTP/2
} [5 bytes data]
GET / HTTP/2
Host: recuida.com
Accept: /
{ [5 bytes data]
< HTTP/2 200
< age: 204302
< date: Thu, 30 Apr 2026 00:59:06 GMT
< server: Vercel
< x-matched-path: /
< x-vercel-id: gru1::m8xqn-1777510746663-c50997431ede
{ [5 bytes data]
- Connection #0 to host 64.29.17.193 left intact
Checking ping to 64.29.17.193
PING 64.29.17.193 (64.29.17.193) 56(84) bytes of data.
64 bytes from 64.29.17.193: icmp_seq=1 ttl=246 time=5.49 ms
64 bytes from 64.29.17.193: icmp_seq=2 ttl=246 time=5.12 ms
64 bytes from 64.29.17.193: icmp_seq=3 ttl=246 time=4.72 ms
64 bytes from 64.29.17.193: icmp_seq=4 ttl=246 time=6.54 ms
--- 64.29.17.193 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 2997ms
rtt min/avg/max/mdev = 4.718/5.467/6.543/0.678 ms
├─────── dig recuida.com
├─────── dig recuida.com via 8.8.8.8
├─────── dig recuida.com via trace
├─────── Output of recuida.com
- Host recuida.com:443 was resolved.
- IPv6: (none)
- IPv4: 216.198.79.1
- Trying 216.198.79.1:443...
- connect to 216.198.79.1 port 443 from 172.23.46.2 port 37100 failed: Connection timed out
- Failed to connect to recuida.com port 443 after 134850 ms: Couldn't connect to server
- Closing connection
│ Time elapsed: 177 seconds
├─────── FINISHED
