There is a bug inside Vercel's OAuth page - teams are not selectable/clickable from the dropdown - likely an invisible overlay blocking pointer events, or your dropdown library not registering mouse clicks in popup context. Keyboard events work fine, a user can press Enter to select a team but it's inconvenient. Mouse events should work on the dropdown in your OAuth page. Please help fix it.
Current versus Expected behavior --> Current: Mouse events don't work on the dropdown in OAuth page. Expected: Mouse events should work on the dropdown in OAuth page.
Steps that reproduce this issue --> It's reproducible with any number of teams to choose from (doesn't matter if the user has 1 or more).
