I have nextjs app and its build fails when I use import property of package.json file. Below is a snippet of my error:
@piszczj/web:build: Creating an optimized production build ...@piszczj/web:build: Failed to compile.@piszczj/web:build: @piszczj/web:build: ./src/app/(app)/account/edit/profile/update-teacher-profile-form.tsx@piszczj/web:build: Module not found: Can't resolve '@piszczj/files/uploader/triggers/video-trigger'Inside video-trigger.tsx I use #src/… import and there is no error in vs code and no error when I build this package only, but when building web app it throws above error. I forked that repo https://github.com/vercel/turborepo/tree/main/examples/with-tailwind and started to implement my changes which are:
in
tsconfig.jsonofuipackage I added"rootDir": "." -
In
package.jsonofuipackage I added:"imports": {"#src/*": ["./src/*.ts","./src/*.tsx"]}, -
in
packages/uiI addedbox.tsxandinner-box.tsxinsrc/boxdirectory, where:
import { InnerBox } from "#src/box/inner-box";
export const Box = () => {
return (
<div>
<InnerBox />
</div>
};- I added
boxinsideweb/app/page.tsximporting it asimport { Box } from "@repo/ui/box/box";
Now, during the build I have an error:
> Build error occurredError: Turbopack build failed with 1 errors:./packages/ui/dist/box/box.js:5:21Module not found: Can't resolve '#src/box/inner-box' 3 | exports.Box = void 0; 4 | const jsx_runtime_1 = require("react/jsx-runtime");> 5 | const inner_box_1 = require("#src/box/inner-box"); | ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ 6 | const Box = () => { 7 | return ((0, jsx_runtime_1.jsx)("div", { children: (0, jsx_runtime_1.jsx)(inner_box_1.InnerBox, {}) })); 8 | };
SO the errors are quite similar, maybe if you can fix that I will be ale to fix the error in my main repo. Any ideas?
