(edited)
I discovered a data leakage issue and deleted the project immediately for security reasons. However I need to access logs from this period for audit trail documentation. Is there any chance I can retrieve my logs? Thanks
Xiaoshenwang110 4568 You protected the system fast, but lost the history of what happened. Once a project is deleted on Vercel, its logs are usually deleted too and can’t be accessed anymore from the dashboard. 👉 Not really recoverable after deletion, unless support can help or you had logs stored elsewhere.
