Hey all, I’m having an issue with an SSL Protocol Error…
Problem
Two custom domains (whimsi.xyz and www.whimsi.xyz) show “Valid Configuration” in Vercel, but browsers return ERR_SSL_PROTOCOL_ERROR. Other domains on the same project (domstack.app, www.domstack.app) work perfectly.
Evidence
Failing - no certificate served
openssl s_client -connect 216.198.79.1:443 -servername whimsi.xyz -tls1_2Result: no peer certificate available
openssl s_client -connect 216.198.79.1:443 -servername www.whimsi.xyz -tls1_2Result: no peer certificate available
Working - valid cert served
openssl s_client -connect 216.198.79.1:443 -servername domstack.app -tls1_2Result: valid Let’s Encrypt certificate
What I've Tried
- Removed both
whimsidomains from Vercel. - Waited, then re-added them.
- Verified DNS is set to DNS-only in Cloudflare (no proxy/redirect/worker rules).
- Dashboard now shows valid configuration, but TLS still fails.
Diagnosis
This appears to be an SNI routing issue at the edge layer — the certificate exists and is valid, but isn’t being served for the whimsi.xyz hostname on certain edge nodes. The cert binding seems incomplete.
Ask
Has anyone experienced this? Is there a way to force certificate re-provisioning, or does this require Vercel infrastructure intervention?
